VenomBallistics
- Aug 30, 2018
- 285
- Joined
- Aug 30, 2018
- Messages
- 285
Actually, I am veering off this idea. What I am finding with the different op amps is that at a point, that happens fairly early, the change in sound is negligible. Especially given the nature of distortion. As a guitar player, and musically, the difference is not significant. But I love learning.
Yup, you're learning.
these are the primary three takeaways of diode clipping where real differences are heard
the change from small signal diodes to LED is significant, as is the symmetrical and asymmetrical architectures.
I've found a good bit more mileage out of the bypass capacitors to be honest.
As a fellow wielder of the six stringed razor, I've come to understand these things quite well ... So much so that I don't really use them as directed anymore. I play tube fired heads. I have the magic these circuits aspire to offer in hot bottles of hollow state witchcraft.
In the next few weeks I hope to begin building a delay / boost pedal. all I want is a bigger signal to send to the 12AX7 in the front of the house and some time based witchery.
But that's me. while I encourage migration to tubes, I also encourage solid state exploration. Mistakes as solid state power levels are quite minor in consequence to the same in tube level power, so it is a great place to play until your error rate and bench protocols reach acceptable levels to host 300 - 600 volt projects.
