How do I connect the pull-up resistor to pin 7 of the LM555 timer?
KAKU
Aug 10, 2021
9
Hi, all, newbies here!
I have a question about the lm555 timer. I try to connect the pull-up resistor to pin 7 of the LM555 timer but it was failing and I found that the pulse width became narrower after connecting.
Hope help please! Thanks!
Moderators note : replaced link with manufacturers link, using the link again will lead to a ban
crutschow
May 7, 2021
987
Pin 7 is the discharge transistor for the timing capacitor.
What are you adding a resistor, which makes little sense?
Post a schematic.
Audioguru
Sep 24, 2016
3,656
The circuit you showed has a potentiometer (a variable resistor) connected to pin 7. If it is adjusted to a low resistance then of course the pulse width is narrow.
KAKU
Aug 10, 2021
9
Thanks for ur quick reply. A simplified circuit is shown below.
Harald Kapp
14,290
I do not understand the original question. You mean the wire indicated in red, do you?
Without the connection to pin 7 the 555 will not work correctly.
Please describe in more detail your problem.
Martaine2005
May 12, 2015
5,287
How is R3 adjustable? Shouldn't the wiper be connected to pin 7?
Martin
bertus
3,849
Hello,
Put a resistor of 330 Ohms or higher in series of potmeter R3, to limit the discharge current.
The discharge current is max 50 mA.
The attaced PDF will tell you more.
Bertus
  • 555an.pdf
Harald Kapp
14,290
No. The connection as shown makes the potentiometer an adjustable resistor (rheostat):
- wiper on top: R3 = 100 kΩ
- wiper to bottom: R3 = 0 Ω (usually a few Ω as the potentiometer will not create an ideal short circuit. That is where the series resistor proposed by @bertus comes into play).
KAKU
Aug 10, 2021
9
Hello,
Bertus
Hello, Bertus! Thank U!
