I came across a shorted diode which needed replaced. It read 0 Ωs in both directions. The part number most significant appeared to be RB30. Above that was a number A34. The silk screen indicated a zener diode. I found a datasheet containing a list of zeners which contained the RB30 sequence inside all the part numbers. One device listed 3A4 as a stamp code. That particular diode had a zener voltage of 9.1 V which seemed appropriate for its location in the circuit, a charging circuit for an 11.1 V battery pack which powered the programming unit. I used a 9.1 V zener which I had on hand. That replacement along with a 330μf cap brought the unit back to life. I am unclear as to what the number referred to as a stamp code represents. A mnftr's inhouse code or maybe minimum mAs required? Really don't know.
