I use 6 - AA NiMH cells together in a 6 x AA battery holder. My application typically uses a timed on state drawing 50mA to 2A. In this application, I have sufficient power to drive the device for 90 to 120 minutes. These times should improve as I refine my circuit values. Each cell has a rating of 2800mAHrs. That rating seems accurate. A dead short across the output of this 6 pack can momentarily deliver around 11 amps. Using an off the shelf charging module, which is designed to charge NiMH and Li batteries, and charging the 6 cells as a single unit, the 6 pack battery delivers 7.xx amps. If I disconnect battery from charger and provide a rest period and recharge, my available current out does increase. The highest charge is reached if I charge each cell individually but that is impractical with this application.Thinking that I could achieve a greater use time from my device if I use 8 cells, I loaded up an 8 x AA battery holder. Even if I charge each cell independently my maximum current out is 6 - 7 amps. If I charge the 8 pack as a unit, my max current (using a dead short across my meter or driving a 1 ohm load ) is 3.5 amps. I have ohmed out each spring connector ( which connects each battery to the next ) and have found no discrepancies. A milliohm meter may give me more accurate readings but the best I can tell is that each connector internal to the 6 and 8 cell holder units, are nearly identical. I have mixed and matched my NiMH cells. I have tried multiple battery holders. I have independently charged each cell to maximum capacity but this discrepancy in max current out still lives. Why? Somebody blurted out "Threshold of material," which I think I have a vague understanding of but from a quite different application. I am inclined to believe that trying to push 11 amps thru an extra 2 cells might not be achievable at the voltage of 8 NiMH cells ( typically 1.2 V per cell ). I am also inclined to believe that I may be overlooking some obvious characteristic. Any thots or info that you can provide. My next stop will be battery theory but even a logical starting point would be much appreciated.
