The Alesis M1 Active Mk2 Problem - capacitors dying from resistors
tampere
Apr 5, 2022
2
I have a pair of these speakers - Alesis M1 Active Mk2 - and one started malfunctioning with the blue light blinking and a rapid ticking noise emanating through the speaker. I looked this up online and found numerous reports of this happening when a capacitor (C8), which is adjacent to 2 resistors that get very hot, fails. The official schematic says the two resistors in question are 47kOhm so I purchased the 3W version from Newark to better dissipate the heat and replaced both the old resistors and the blown capacitor. However, after wiring everything up, the speaker didn't work. I reinstalled the old resistors and it did work, which made me wonder if the official values were incorrect. Indeed, they were. The old resistors are both 37.4kOhms to within a few tens of ohms.
I have a few questions:
1. As I understand it, resistors increase in resistance as they age, so the measured values of 37.4kOhms can't be due to aging if the schematic values for these resistors, 47kOhms, is correct. Furthermore, they are very, very close in value to one another (37.41kOhms vs 37.48kOhms - what are the chances they would age nearly identically?), which makes me think they are, in fact, originally 37.4kOhm, 1% resistors - I know the last band, gold, is a 5% tolerance. Why would the schematic say one value and the actual resistors be another? Why such a specific resistor value? Why not 36K or some other much more common resistor? I've tried finding this particular resistor and these are rare as hen's teeth. Orange-Brown-Red-Gold? Orange-Yellow-Red-Gold? Red-brown-red-gold? Thoughts?Original Alesis M1 Resistors.jpg
2. With the new 47kOhm resistors in place for the original fix, rather than not turning on at all, I guess I would have expected the speaker to malfunction in another way like not being as loud. What would be your expectation for what would happen if 2 37.4kOhm resistors were replaced with 2 x 47kOhm?
The schematic, which you will need to make sense of this question can be downloaded here. The resistors in question are R3 and R4.
Thanks for your insights!
P.S. I measured the resistance of the original resistors using two different multimeters. I also tried to read the resistor color code but it is faded.
Audioguru
Sep 24, 2016
3,656
The schematic "Cannot be downloaded securely".
My pc does not know what kind of file type it has. Maybe it should be a PDF.
tampere
Apr 5, 2022
2
Here's a pdf of the service manual / schematic.
  • ALESIS M1 ACTIVE MKII.pdf
kellys_eye
Jun 25, 2010
6,512
Change C8 - it's DUD!
The resistors are probably ok and don't need changing but if you want to.....meh. They're only there to 'balance' the voltage across the two main smoothing capacitors (C6/C7).
Measure the power supply output and see if it is within spec. I reckon replacing C8 will fix whatever issues you're having.
Audioguru
Sep 24, 2016
3,656
The schematic of the amplifier show that R3 and R4 feed the "mute" pins of the amplifier ICs with a low current.
kellys_eye
Jun 25, 2010
6,512
The schematic has them at 47k. The 37.4K you measured was possibly as a result of them originally being fitted as 36k devices (one of the E24 range) and this fits with the discolouring if the middle band was originally blue. The original resistors are probably still ok despite their discolouring.
Although the value found is different from the schematic value it may be as a result of the controller IC1 minimum current requirement.
Laundry_Hamper
Jun 16, 2023
1
Here's some information for anyone ending up in this thread from search results hoping to repair their M1 MK2s by replacing the PSUs outright, or looking to convert the speakers to passives:
Code:
Alesis M1 Active MK2
Woofer: 75w, 8 ohm
Tweeter: 25w, 4 ohm
Crossover: 2kHz
    "Specifically in the case of the M1 Active Mk2, the wide, mid-frequency
    polar response of the tweeter can be utilized down to a low 2000 Hz
    thereby mating more cohesively with the 6.5" non-woven carbon fiber
    (NWCF) woofer. This low crossover point is only possible through the use
    of a steep, electronic fourth-order (24 dB per octave rolloff) high pass filter."
PSU output to tweeter: 18V
PSU output to woofer: 36V
Tweeter amplifier: LM2876, input range 20-70V
Woofer amplifier: LM3886, input range 20-84V
PSU cable connector pinout (to crossover/amplifier board):
      |   -V_LO    |   (green)
    c |   +V_LO    |   (red)
    l |   AMP_GND  |   (white)
    i |   SIG_GND  |   (blue)
    p |   -V_HI    |   (green)
      |   +V_HI    |   (black)
Amp datasheets:
Personally, I'm going to replace the C8s, move the two resistors further from the boards, rehouse the PSUs in a box that can sink even a small amount of heat and mount them on the outside of the rear panel so they aren't stuck in a well-insulated box. If that doesn't work, I'll probably just get some appropriate crossovers and turn them into passives.
In all the posts about the problems with these speakers, I haven't seen these aspects highlighted...scorched circuit-boards and holes melted into the batting! These PSUs are a "good" design, the power supplied is quality, but the oversights are absolutely godawful:
