I've been looking for a free online one of these. I tried the LTSpice modeller first that was suggested for modeling which is ok but does not really fulfill what I need in terms of straight schematics rather than modelling, as there are no connectors for example that I can find at least.
I then tried Digi key which seems ok, but all the connectors don't match up with the number of pins on the drawing object and I cant find a way to make them, so for example a 15pin male connector single in line has 17 pins on it shown on the schematic.
Also, you cant create a composite object for example I want to represent some components on the inside of a keyboard and its 2 * 15 pin connectors, so this would require a rectangle, some connectors and a few components inside, this indicates its inside the keyboard and is clear. Then on the exterior of this box are all things which connect to it for a test rig, get where I am coming from.
I'm probably doing something wrong , and its simple stuff, so nothing complicated, so I thought ( Light bulb moment ) why don't I ask the professionals here for advice, I'm sure there are some of you using something like this already.
Cheers - Terry
Cheers - Terry
