roughshawd
- Jul 13, 2020
- 616
- Joined
- Jul 13, 2020
- Messages
- 616
I would be probably better off just buying a new PBA and put it in the fridge, but I feel so close to fixing it!!!
Everything still looks good, in fact the readout seems to be running better than it did before except that the sensors are not proper, and read out -8 degrees while the Wi-Fi tells me the fridge is ok and in actuallity, it is not cooling down at all !!! and sends an error back that says the freezer is overheating.
The main PBA board is different from the one in the repair manual... I can say and will post some pics... that the GGHI4-PJT C/NO
A41-00827B 2016.12.28 Ver.01 B178X197, does not have the same configuration as the one in the book, but, it does seemingly does have the same pinouts. the board, having a part ID QR scan code of 06DA9404399E 100DMBC0311 is all parallel in sensor pinout and all series in Power pinouts --- Where the power pinouts driver heaters, motors and one lamp, and the sensors .
I had it cooling fine, sensors to the readout panel was working, did some repairs and it stopped cooling down.
Defined as something that I did, changed something!!!
better tie me down to the kangaroo and put me on a daily vigil... I think I'm going to be here a while!
I am going to try some things, and I don't need you guys getting upset about it. Its just an old junker smart fridge!
First thing I want to try, is going through my notes and see if I have the wires I fixed in the correct places... working laying down in the floor, and trying to wire a plug in under the front of the fridge with about 2" of space to work in was slightly disturbing!!!
Then I am going to turn off the individual room heaters, so the individual rooms will cool down rahter than defrost... As they may be defrosting all the time, keeping the rooms nice and dry and warm... this is on the assumption that the system might adapt to a failing door sensor, and warm up the fridge, so it doesn't blow up the compressor trying to keep itself cool. then I am going to indivdually disconnect each system, restarting on 15min intervals to allow everything to adapt to its failing system. there is an EEProm on the board in the book, and if i can reset the one on my board, it just might rebuild its index and restart the system.. I think that 20pin port is a diode option setting port.
The board in the book is a ROMANEE-CONTI-PJT C/NO
A41 008( )A 2012.04.25 Ver.01 but I can't read the final number.
17 B or 8 something something 7. I would like lines to both these replacements if you got them!!!
GETTING PICS FOR YOU!
