Use speakers with AV receiver
Rizwan77
Feb 5, 2023
25
Can I use Sony SR4W speakers with any AV receiver ?, because my Amp showing some fault , so I am thinking to buy some AV receiver and use existing speakers
Harald Kapp
14,317
The amp needs to be specified for the impedance of the speakers, typically 4 Ω or 8 Ω, the it should work.
Rizwan77
Feb 5, 2023
25
I want to try on Onkyo TX sr-308, which say minimum 6 ohm , so these are useless
crutschow
May 7, 2021
991
Not really.
The manual says it will do:
• 100 Watts/Channel @ 6 ohms (IEC)
and it also states:
• You can connect speakers with an impedance of between 6 and 16 ohms. If you use speakers with a lower impedance, and use the amplifier at high volume levels for a long period of time, the built-in amp protection circuit may be activated.
So you can use 4 ohm speakers with the limitation that it may cut out at high volume levels, but I suspect that is above the volume you typically use, unless you like loud hard-rock music.
Rizwan77
Feb 5, 2023
25
How can I know the limitation, what happened on some movies with any blast sound
crutschow
May 7, 2021
991
That's a short burst.
The amp will likely only cut out from heat build-up for long duration, high volume sound.
Also most of the sound energy of that movie blast is likely in the bass region which will be handled by the subwoofer, which should have it's own amp.
(Are you planning to use the Sony subwoofer also. That does not appear to have a built-in amp.
If so you would need to add a subwoofer amp, such as one of these, since the Onkyo does not have a built-in sub amp, only a line-level sub-out signal.)
Rizwan77
Feb 5, 2023
25
Yes, you sort out things right, I want to use woofer , but only cheap amp available from my location
Rizwan77
Feb 5, 2023
25
what kind of amp required to use Subwoofer with that type of AV receiver ?
Rizwan77
Feb 5, 2023
25
Now , I found a sony system without speakers, dz640, which comes originally with 3 ohms speakers, Can I use this to mine speakers, which are 4 ohms, also mine broken sytem was about 800 watts, and this is 1000 watts, but seems to very close to work, suggestions required
crutschow
May 7, 2021
991
An amp will always work with speakers that have a higher impedance, since the output current and power is reduced.
And I see no problem with the higher power rating of the amp since the power with 4 ohm speakers will be 750W.
Given that rating, it wouldn't surprise me if both amps are actually the same.
