Recommendations for a timer switch 12V boat pump
David.Bundy
Mar 16, 2023
1
Hello, I'm new to the world of electronics and looking for some advice. I have a boat that is parked about 30mins away from where I live in the UK, it rains a lot here and therefore my small boat fills up with water. Its kept up on a trailer so with a 12V bilge pump and a long hose I can prime a syphon.
As the pump only needs to run 5-10 seconds to prime the hose, a simple float switch on its own will use too much power on my leisure battery. I was thinking of using a timer switch so run in a series with the float switch to create the syphon and once the next timer goes off the boat will be empty (no circuit from the float switch).
Is there a 12V timer switch on the market for my needs? lets say every hour it turns on for 5 seconds.
Thanks
Dave
kellys_eye
Jun 25, 2010
6,512
Really? Most simple bilge pumps chuck the water out at 500 to 1000 gallons per hour (2-4000 litres/hour) equivalent to a minimum of 0.5litres/second.
Assuming a 20 litre 'flood' it will take 40 seconds i.e. under a minute and at a current draw of typically 2-3A.
Assuming worse case (3A) this represents 1/20th of an ampere-hour...... a typical leisure battery would be (say) 70 to 120Ahr so you could drain a 20 litre 'flood' some 700 to 1200 times and only discharge the battery to HALF its capacity.
It must rain a lot where you are!!!
PS - I'm in Argyll, I know what 'rain' is!
