Need help with SMPS voltage output high
Edib
Mar 19, 2023
3
SMPS Schematic
https://www.allen-heath.com/media/xone_db4_db2_004_066_psu_2.pdf
Hello there
I have a music mixer failing components downstream from the PSU. After some investigation, I realized the voltage output from the PSU is higher than specified on the board or schematic.
Output should be +/-12 however reading 19v or higher. I attached a 10ohm 3w resistor to pins 9 and 3 on CN1 (see schematic) and the 12v rail jumped to 26 v.
What may be going on here?
kellys_eye
Jun 25, 2010
6,512
Pins 9 and 10 form a separate ground from the other supplies.
Edib
Mar 19, 2023
3
I see your point.
When I measure pin 1 against 9 (proper ground), I still see a much higher voltage output than the specified +/-12V.
When not loaded, the PSU outputs +/-15V. When I load the 5V supply rail, the 12V output more than doubles?
Is this normal?
