Usage of BEC on a PRI Pico drone
lovrinho
Apr 5, 2023
13
Hi all :),
I'm building a drone on a Raspberry Pi Pico W and I need advice on how to use a BEC or rather which one. The battery I will be using is here (3S 1800mAh 30C) and BECs I find give out 5V 3A (like this one). Now 3A is the maximum constant current but can I use this to power just my PRI Pico W and is the BEC on the link useful for me to order?
Thanks in advance
Bluejets
Oct 5, 2014
7,374
Don't see why not.
Directly from the data sheet for Rasberry Pi Pico W ........ Raspberry Pi Pico W uses an on-board buck-boost SMPS which is able to generate the required 3.3V (to power RP2040 and external circuitry) from a wide range of input voltages (~1.8 to 5.5V).
Imagine you need to watch you feed the voltage to the correct power input.
lovrinho
Apr 5, 2023
13
Don't see why not.
Thank you :).
It seemed okay to me I just wanted to make sure.
