Hellmut1956
- Aug 11, 2014
- 74
- Joined
- Aug 11, 2014
- Messages
- 74
As usual, I try to figure out what is the path to add or modify peripherals that are fed by the flight simulator. I have purchased a bunch of peripherals and by the time I get to the intended end working on my workshop and on setting up the cockpit. The first step in getting into the electronics so to understand protocols, and even more basically, how the flight simulator feeds data to a peripheral. On one side the simulator will supply data a peripheral needs and on the other side, the peripheral has to know how to request data and identify the data streamed to it. Looks like the data is transferred by PWM. I have a logic simulator that connects to the PC via USB and it can identify by itself the protocols the data transferred and report data filtering it to the protocol used.
I am opening this thread to make visible to forum members that I will get deeper into the electronics as they are used between flight simulator software and peripherals. Long-term building a cockpit that moves the seat on which I will be seated and do so also with the monitors. I am aware of that seeing the advances in VR and its ecosystem, i.e. the new goggle from Apple, fascinating things will become possible.
