To talk to who? Another 'cordless' (of the same series)?cordless handset base
Yes that's exactly what I want to do!I know yours is not a VTech but this is basically what you want to do yes? or no? thank you.
If the answer is yes then I would put a Schottky diode in series with positive 5volts which would drop the voltage down approximately 0.3 volts giving you around 4.7 4.8 volts. If this is not done you run the risk of overcharging the batteries they will heat up it will not last as long as they were intended.
Yes I have a phone that it connects to. My only question was charging the extra handset using a USBTo talk to who? Another 'cordless' (of the same series)?
If you want to make a phone call then use the local telephone. Your cordless set won't give you any functionality and certainly won't work with anything other than another handset of the same type/make.
Exactly which Schottky do I buy? and connect to the non load side?And the answer is yes!
I've done the same thing but with the Schottky diode although if you do not insert the diode you must remember not to keep it on the handset overnight just charge it until full and take it off the charger and that's a pain in that you know what!
And be careful who you talk to in Europe they're a bunch of crazy good people out there in The boondocks.
