SamBushman
- May 4, 2023
- 12
- Joined
- May 4, 2023
- Messages
- 12
I have the following Motherboard: https://theretroweb.com/motherboards/s/pcchips-m560-v3.x
Last time I went to use this PC, the computer unexpectedly locked up, then became very unreliable when attempting to boot and post. After doing a visual inspection, I found some bulging capacitors. I went ahead and replaced them all. After finishing this, I then noticed the Inductor Coil next to the CPU was damaged. Specifically, the ring the wire is wrapped around has split in 2.
Reading online, it appears that air gaps in the ring will lead to worse performance evening out noise on the voltage line (something I'd expect the CPU to be sensitive to). I suppose I could try either leaving the coil alone or glueing the ring back together. I'm not excited about either of those solutions, as the ring would still be performing worse than new and IDK how bad this would impact my computer's stability. I'd prefer to buy a replacement coil.
It looks like I could invest in an LCR meter to measure the coil and search for a spec-equivalent replacement (I assume I'd need to match the uH rating, size, and mounting method?). However, I don't know if those measurements would be skewed by the fact that the inner ring is damaged. So not being able to find any schematics and not being sure how/if I could derive the intended specs I'm kinda stumped how to move forward here. Do folks have any wisdom?
Thanks!
Thanks!
