"Portable" system to output power from solar to a notebook
Martaine2005
May 12, 2015
5,315
The shop told you items to get. They are about right. If not, the panels will not be portable but very big!.
analoglight
Jul 4, 2023
13
I don't mind to transport one "big" panel. I just need to understand which one I should get regarding to the technology and so on.
Delta Prime
Jul 29, 2020
2,993
I just need to know what other components I need to have a 220v output interface. The laptop doesn't have usb-c power input
Is it possible to take a photo of your laptop where do you plug the power in also where it has a specifications the model number of your laptop please and I will work on your request thank you.
analoglight
Jul 4, 2023
13
Delta prime: Forget my laptop. My aim is to get an 230v power interface from solar panel to transport it at car. Just that.
Delta Prime
Jul 29, 2020
2,993
You're going to need a controller.
And here is an inverter
What is missing in the photo that particular inverter is from 12 to 24 volt input so your car battery will work with this unit. Or anything similar. Power will be derived from the 12 volt battery to the inverter and your photovoltaic panel will charge the battery via controller in your vehicle but that could be a problem .
Delta Prime
Jul 29, 2020
2,993
Forget your laptop?
Okay it's done I forgot it what laptop who said anything about a laptop. You still going to need a controller and the inverter and your choice of solar panel try to get a solar panel as big as you can that you can stuff in your vehicle it could all be done with 12 volts but you're going to need your car battery to do it!
Delta Prime
Jul 29, 2020
2,993
The controller inverter was just an example I'll go shopping see you tomorrow
analoglight
Jul 4, 2023
13
I thought I was quite basic at my aim, seems it is difficult to understand it.
Thanks all.
analoglight
Jul 4, 2023
13
Choices:
Battery:
Converter/Controller/Charger:
Solar panel:
What do you think?
Delta Prime
Jul 29, 2020
2,993
When you travel around the world I hope you make it to the United States specifically Los Angeles California so I can ring your neck!(just kidding)
:p
Delta Prime
Jul 29, 2020
2,993
That's okay I have a really long extension cord and I will literally hook you up to it.Sparks will fly, you're all set kid!Now get out of here. And don't be a stranger.
