Delta Prime
- Jul 29, 2020
- 2,993
- Joined
- Jul 29, 2020
- Messages
- 2,993
Well yes you see there's a distinction between electronic circuit theory you don't have to dive into the rabbit hole "physics"Probably most people even electronics workers don't realize they are basically working with those same forces as those who construct nuclear weapons
only the underlying principles.
Cuz you're not paid to do that. My previous employer was a practicing theoretical physicist.
I was given a set of instructions to follow "schematics"for prototypes or to alter existing technology because the experiments that he would conduct, the test equipment did not exist. . At that level,( my level ) Ohm's law is good enough. As far as constructing nuclear weapons the scientists themselves could not be certain of the outcome when the first nuclear bomb exploded.You see it was uncharted Territory, never done yet. Electronics can be quite fun and rewarding you should try it, get yourself a electronic kit, the kits come with all the components that you would need PCB as well. All you have to do is learn how to solder look for something that you use almost on a daily basis "there's a kit for it".
