Okay this is my first post to these forums hopefully it's in the right spot.
I have a 3-speed fan that the slowest speed it's not very slow. It's an AC current fan but I haven't hooked up in my RV through an inverter that provides me house power. The issue I'm having is that the speeds are not very far apart. When I have it on the slowest speed it still sucks down the battery. I haven't taken it apart yet but I'm thinking that after the switch the power going to the motor is probably reduced by resistors. I don't know I'm just guessing. So I want to put a more resistant resistor in between the low setting on the switch and the motor. I know it's kind of a relative thing and I wouldn't even know what size or capacity resistor to use. (And what RPM am I trying to slow it down too?)
One of the questions is, if I put a resistor in line that's cutting down the power to the motor therefore reducing the RPM is the motor still drawing the full power and the resistor is just creating heat as a way to dissipate that extra power? If that makes any sense. So in other words, with a modified resistor would the motor still be drawing the same amount of power from my battery in order to create the AC power? And what size resistor, or class of size of resistors, would I be looking at to splice in?
