But I'm sure I could have noticed. I was working on it when I noticed something that wasn't there some moments before. Anyway, what are my options?It's seen some pressure or abuse despite your concern.
Thanks for the advice.Two options:
1. Live with it
2. Change the screen
I really appreciate. I will will try to do that and come back with feedback. Any examples of things I should look for? I have always thought external factors cause the excessive pressure on LCDs, however, I immediately like your insight as it makes a lot more sense especially in my case where I could swear there hasn't been any external excessive pressures on the the LCD.You can try to open the LCD, find the cause for the excessive pressure and relieve that pressure. Make sure the laptop is off while you open it. Of course, once open, you wil have to power the laptop on to see the effect on the LCD. Once you managed to relieve the pressure, turn the laptop off again and close the LCD.
Be very careful when working on the LCD, there are delicate cable assemblies which need to be handled with care.
Wonderful! I will try these. Thanking you immensely for your guidance. I will provide feedback.See e.g. these instructions:
How to Remove a Laptop Screen: 8 Steps (with Pictures) - wikiHow
Safely disassemble your laptop in no timeThis wikiHow guide will help you carefully remove and replace a damaged laptop screen. Find the screw covers and remove them with your hobby knife or box cutter. Laptop screens have rubber screw...www.wikihow.com
How to Open a Laptop Screen | Techwalla
The LCD screen on a laptop is frequently the first component to experience problems. Although opening a laptop to replace or repair internal components is more difficult than with a normal desktop, it can still be done at home by the average computer user with the time and patience to do it.www.techwalla.com
Or ask your favorite search engine for instructions that are specific for your laptop. When there is one, this is imho your best option.
This is noted with thanksA common cause is to forget you've put a pen or other object on the keyboard and then closed the lid, realised it's there then removed it to properly close it. By that time the damage has already been done.
