I have the KBMS1454SSS-3 Microwave that has a relay that clicks rapidly when I hit the start button to begin a cooking cycle. I have replaced the 4903 M/W relay on the board as well as 3 of the capacitors however the problem continues to exist. I tested each capacitor that I removed from the board with an EMR meter and all tested good. Since I hear the 4903 relay chattering I removed it from the board and used my 18V makita battery to bench test it. It appears to work fine on the bench - apply the voltage and it fires the relay, no chatter. I replaced the relay and the new relay behaves the same way. I'm stumped as to the cause of this relay chatter. It seems like it must not be getting adequate voltage but I'm not sure what to check. I would appreciate receiving direction on what to look for. I'm a handyman, not an electronics technician. I've repaired microwaves in the past usually amounting to swapping out magnetrons but occasionally replacing board relays or capacitors. There is an 8 pin transformer on the board with the number 467123810 stamped on it but it doesn't have any visible damage to it nor can I identify what the replacement part would be if I were to pursue replacing it. Attached are pictures of the board along with the tech data sheet for the unit.
