I have a 3000 watt inverter in my truck. I haven't mounted inside the truck to prevent it from getting the heat from the engine compartment. So I have to run the positive wire through the firewall to the battery. I'd say it's about 8 to 10 ft Max. I'm using a set of jumper cables for the wire. They're not that great of a gauge so for the positive feed I use both the positive and negative of the jumper cable and twisted them together to make the positive lead. Same with the negative but the negative is only about a 1 ft stretch mounted to a grounded section where my console mounts inside. Now this is a two-part question. First, the positive cable heats up where it connects to the battery. To the point where you can't even touch it. It's gotten to the point where the wire started deteriorating and eventually broke off. One of the questions is is my negative connection too weak. In other words, if my positive connection was big enough gauge wire to allow proper flow but the negative wasn't as heavy gauge allowing the throughput that it needs to match the positives amperage flowing through. I guess my question is would that cause the positive connection at the battery to fry? And I know I need a breaker or a fuse in between there but I've been using it without one which is bad. So I'm going to rewire it this weekend I ordered some 10 gauge battery cable / welding lead wire. I'm going to use that for the positive and the negative and find a better place to ground it. So I guess my question is if you have a strong positive and a weak negative will the positive tend to heat up and melt off or pop a fuse? And is 10 gauge wire enough to allow the flow for a 3000 watt inverter drawing maybe 750 watts of power?
Thanks for any help and insight on this.
