i want to be able to turn on my pool pump on and off remotely. the pool pump has two separate buttons for on and off. solenoid requirement stroke is 1/8 inch with 1/2 pound. i have an electrical outlet 110 volts ac that i can control remotely via wifi. i want to have two solenoids, one solenoid to turn on and the other to turn off. when i turn on the electrical outlet via wifi, i want the one solenoid to only pulse 1/2 second and press on the on-button on pump, not continues, only pulse. then i want the second solenoid to do the same, 1/2 second pulse, but to press on the off-button on the pump, when i turn off the electrical outlet via wifi. i will have another electrical outlet for powering my device project. i want to build this with just the old fashion ordinary-over-the-counter transistors, resistors, capacitors and of course solenoids. nothing with audrino nor raspberry pie stuff. also, please give me recommendation for micro solenoid to use. i've seen some products on amazon.com but they're 80-150 dollars. i know i can build something much cheaper with your help. i'm frugal not cheap. i have a pool party in two weeks and i hope to accomplish this device project. can any of you geniuses here on this forum help me please. i would greatly appreciate it. thank you. B
