I connect a resistor to both sides, but no current flows. If I remove the resistor it gets current. Why is this happening?
I connected a 3 ohm resistor, the current does not go away, if I remove it, it goes away. This is the power unit.
My purpose is not to ask troll questions, but to reduce the voltage of the power unit. I could not achieve 7 volts. Its value does not change. When I connect a resistor, it cuts off.
It's not worth it for something like this, a 7 volt one is on sale, I'll buy it from there, but thank you very much anyway.
