C:
// constants won't change. They're used here to set pin numbers:
const int PushButton = 2; // the number of the pushbutton pin
const int MOTORPin = 9; // MOTOR connected to digital pin 9
// variables will change:
int buttonState = 0; // variable for reading the pushbutton status
void setup() {
// initialize the pushbutton pin as an input:
pinMode(PushButton, INPUT);
void loop() {
// read the state of the pushbutton value:
buttonState = digitalRead(PushButton);
// check if the pushbutton is pressed. If it is, the buttonState is HIGH:
if (buttonState == HIGH) {
// turn MOTOR on:
digitalWrite(pinMode, HIGH);
} else {
// turn motor off:
digitalWrite(pinMode, LOW);
This code can't work. I don't even understand how it compiles without error ...:
digitalWrite(pinMode, HIGH); -> makes no sense at all as pinMode is also not defined as a variable or constant anywhere.
Your code should look something like this:
C:
void setup() {
void loop() {
do you have the required pull-down resistor attached and pushbutton is connected to Vcc? Show us the schematic.
commonly the pushbutton is connected to GND and the input is set to
PULLUP. This spares the external resistor.
however, a pressed pushbutton is the logic LOW (inverse logic)
you need to
debounce the pushbutton. Otherwise the behavior will be erratic at best.
Code:
// turn MOTOR on:
digitalWrite(MOTORPin, HIGH);
} else {
// turn motor off:
digitalWrite(MOTORPin, LOW);
