Hi all. This part has me confused. The color code (Brown, Black, Red, Silver) for it to be a resistor, would make it a 1K Ohm value with a 10% tolerance. Testing it with a multimeter set on Ohms, it comes out to 8.3 ohms, which would obviously be quite low for the value, if it is a resistor.
When I insert it into a component checker, it returns as an 8.3 ohm .90 uH inductor (tester uses mH instead of uH, I think- see the pic). The same color code (Brown, Black, Red, Silver) in an inductor chart shows it would be a 1.02 uH inductor with a 10% tolerance, which would almost fit the tolerance. However, if I change the tolerance to 5% (Gold), the app I am using turns it into a 10.2 uH inductor with a plus/minus 5% tolerance. I wouldn't think the change of a tolerance would also change the uH value, would it? Maybe a glitch in the app I'm using?
So I can't tell if it is an inductor or a Carbon Composition Resistor, although the pictures I have looked at so far would indicate the latter. Does the coloring on the long leg of the component indicate something? It has a brown colored coating on it too. I don't think typical two lead inductors are polarized, are they?
So thanks in advance for your replies.
