I work with HMI made for PLC,I have never worked with one UART
You're mixing concepts:
- Modbus is a protocol. A set of defined commands and messages that allows interfacing different components independent of teh manufacturer (more or less). Modbus can be used on different media, e.g. Ethernet (Modbus TCP) or RS485.
- A UART is a hardware interface for serial protocols. A UART can be used to communicate via e.g. RS232, RS485 etc. WHt protocol is used over the UART interface is a completely different matter.
When Modbus is used over RS485, then typically a UART is used to manage the hardware side of the interface, plus so called "transceivers" which handle the RS485 voltage levels (which are completely different from the logic levels a typical UART would use).
In your case the PLC obviously uses MODbus over RS485, which means there is a UART on the PLC side plus the above mentioned transceivers plus software running on the PLC that handles the Modbus protocol. Interfacing with this requires the other device (here the HMI) to also have the same physical interface (RS485) and the software to handle the Modbus protocol.
I may be wrong, but as far as I understand the STWI070Whas a protocol of its own which is
not Modbus. Therefore you will not be able to establish communication between this HMI and the PLC using Modbus.
From the datasheet, chapter 1.5:
1.5 Working Principle The Intelligent TFT-LCD Module communicates with the Customer’s MCU / CPU / FPGA / PLC via Commands (JSON command and HEX Code), and thenthe MCU would control its connected equipment to work according to the received commands.
(emphasis by me). You may be able to coax the PLC to work with this HMI by writing your own interface software for teh PLC such that the PLC can create/send and receive/understand the commands and data according to the HMI's own protocol, but that is far from a no-code solution.
