Physics Project in need of some expertise
radiumh
Nov 3, 2004
2
I am more of a physics geek then an electronics one, i need to control and monitor a physics experiment.
first i need a circuit that will create an adjustable square wave,
frequency in three ranges 0 to 10 Hz, 10 to 100 hz, 100 to ~1khz.
i need to be able to adjust the pulse width appropriate to the range in question.
the pulse must be split between two channels each other pulse alternating between an output A and B.
the above will be the primary controller for the experiment. :-\
i expect the critical frequency range to be in the 200 hz to 600 hz range.
some how the pulses need to drive a final output to the experiment with a voltage that can be adjusted between 10 volts to 40 volts at approx 2 amp at the max frequency of 1khz.
these finel pulses are driving two coils. A and B.
this request is probably not not very clear and i expect will have to be expanded upon but it is a starting place.
Olihou
Oct 1, 2004
48
Your requirement is not very clear to most readers, I am afraid.
Perhaps you can describe what your physics experiment is so that others will know what you really want.
Also a block diagram of the circuit you like to have should help.
Oli
