Haha I`ve been using this method for making PCB`s for year and more.There are a little secrets for making these PCB`s.
First for me I`ve tried so many types of paper but I think that the best one is Ink Tec`s Premium photo paper.
The most important process is the ironing most of people say that the PCB should be ironed for 2 or 3 minutes at full temp. That`s not true because in most ot the photo papers there is around 40% of Polypropylen and Polyethilen when you fry the paper with such temperatures the plastic in the paper stick on the PCB and happens nothing the best temp for is 140 degrees.
Putting the board in water is a mistake because you will remove the paper harder than if you try removing it gentle when it`s dry.
If there are broken tracks you can fix them by redrawing them with a permanent ink or straight a permanent marker I use Schneider S303.
After that you can put it in the FeCl3 and etch it.
I know other methods for really fast etching for about 1.5~3 minute etching using electrolysis but I`m going to write a topic about that method Has someone ever experienced with that method? ???
Hope I`ve helped you :
