Playing with hydrogen
steven2
Jan 19, 2004
1,698
:)ante a diode electrode is a diode cut in half then each half is used as an electrode so the diode works good even in 2 halfs for assisting in the process of rocket feul separation from plain tap water , your in sweden ,arnt you closer the big nuclear pack , where the bangs are bigger and you need sunfacter 500 pluss lotion for the energy burns, if i doodle the diode setup instead of createing rocket feul i get clean hydrogen , or both depending on which diodes i use the funny thing is the water turns light black mostly on the top and mostly above one side of the container when i first tested it out and the big bubles instead of going up they move accross towards the other electrode but they rise up half way isent that odd , however the smaller bubles tiny ones all come strait up like that from an air stone in a fish tank , and i can hear them ok even with the radio on down stairs so i hope to improve it more and have it sound better than that of the bubles in lemonade
ante1
Jan 24, 2004
4,138
Hi Steven,
Oh, I see. Do you use plain tap water with no additives? Does it really conduct well enough to produce hydrogen? What voltages do you use and what current does it draw? What about the diode electrodes, do they corrode and disappear or can they withstand this for any length of time? Maybe the black stuff you get in the water is the result of corroding electrodes. It sounds very strange that bubbles could go sideways, like magic. ??? Yes we have nukepower here but they are very safe which could not be said for the Russians and eastern Europe plants which unfortunately isn
steven2
Jan 19, 2004
1,698
:) hello ante the pages are working for me now your sentance was so long i have to move the page left to right just to see it all, or for a bit of humour right out the side of my computer and onto my desk just to read it all, the diodes are ok the only black on top of the water would have to come from the black diode boddy and as for the electrode or what ever you call it silicon stuff if it is looks like black volcanic ash but it appears to be covering something metalic as i can see around the edges of it the diode body is holding out well and ill varnish it next time to see if i can stop the water getting lite black from whatever is in it, dazza thought id blow the pvc pipe setup to bits but i aint gona be igniteing it all mixed up not even in the open end that aint conceild to be able to make big bangs, the idea of useing just the hydrogen would do for the time being , im not ready to get back into my old intrest in rockets just yet so im phocusing on the the hydrogen use
steven2
Jan 19, 2004
1,698
:) my hydrogen oxygen generator setup is similiar to these ones im useing spit diodes for electrodes the other ones in these pictures uses stainlless steell wooll and its e shaped like mine i made mine from all from 2 pvc pipes, a thin one and part of a large diameter one. the one in the pictures is made up of elbow jionts etc etc which i couldent find the right parts to make this,
steven2
Jan 19, 2004
1,698
:)in these pictures is the finished hydrogen oxygen separator as ill call it , so the positive half diodes are in one chamber and the negative half in the other chamber , i can still add more diodes or if i like i could do it in a way as to produce them as a mixture but it would be exsplosive so ill leave it as it is
Dazza
Jun 21, 2004
591
Good work Steven, I have a suggestion :), see drawing. A clear hose will allow you to monitor the water level in each chamber :D.
steven2
Jan 19, 2004
1,698
dazza ill be doing that some clear hose just above the chambers to so if i over fill it the water will run out and ill use those little plastic taps to shut it off so the gass wont come out i can put some windows in the chambers to view the bubles to , those plastic lenses from old cameras are usefull to and ive got them around to ,the top of the outlet pipes i can seal them and put plastic valve taps there to ,the same ones you use for the air hose to air stone in fish tanks , at least the gas will be more concentrated when comeing out of the outlet pipes and from there i can channel it through more plastic tube ,or just a rubber tube and to the brass nozel peace from my dead gas powerd soldering iron, allso im planing to try powering it from my high voltage photo flash capacitor charger as even with one capacitor is good and 2 in parralell much better so ill see if i can get more gas output at a faster rate if possible,
Y
Yevgenip
Jan 1, 1970
Be careful though, if you mix hydrogen and oxygen 2:1, you get an exploding mixture.
steven2
Jan 19, 2004
1,698
:)i know that i used to be into the rockets and space ship stuff but then i got intrested in fying saucers
Dazza
Jun 21, 2004
591
Are, I see now, you are secretly trying to refuel your spaceship so you can return home. 8)
Dazza
Jun 21, 2004
591
Hi steven, I'm sure you realise that their is a couple of critical design flaws in this design ;), as well as most of the most important parts are missing. Apart from this, it gives a good overall idea on how it could be done 8).
Do You have the second page to this design, I will post it if you don't have it :).
steven2
Jan 19, 2004
1,698
:)dazza its a big one and i found it on the net, i just thought id post it for your convenience, i dont know if theres anymore details to it , maybe there is, but anyhow hydrogen prduction is the way to go, im looking forwrd to seeing more of your postings on this topic
Dazza
Jun 21, 2004
591
Here is the second page to that design.
And this link contains the rest of the information for it ;).
(<http://www.hasslberger.com/tecno/hydrogen.html>)
Dazza
Jun 21, 2004
591
Steven, the block diagram for my design is on page 5 of Schematics Variable current 12v 60A to 0A :).
steven2
Jan 19, 2004
1,698
:)dazza here is a few pictures of the bakeing soda rectifier printouts, unfortunately my camera cant get the whole pages in ,and i cant find the site again, as if its disserpeared, you can try if you like ,there are a few other pages to but ill give you the what i can get with my camera
