flippityflop said:
i'm asking as i've been working on a design that to my understanding should've worked. i have a generic NPN restoring the supply voltage and feeding it's emitter output to a 2N2222 parallel to a charging capacitor for a delayed avalanche. somehow the avalanching only works when i swap the 2N2222 + charging capacitor sub-circuit to the collector side.
it surprised me as when it was connected to emitter, it was also directly connected to ground. and when it was on the the collector side it was directly connected to the supply. so it was not isolated and would be biased to a common ground. although, as a side note, when it was on the emitter side, the charging capacitor might have caused a reverse current through the generic NPN and leaking to other parts of the circuit. so i probably should've put a diode in there. well i didn't get the chance to as i blew my 2N2222, so now i have to go to my local supplier to have more.
charging
so i'm not completely sure what to make of it...
EDIT:
the generic NPN is "on" strictly less than the time needed by the 2N2222-capacitor sub-circuit to avalanche.
answering my own question again:
it just struck me, but maybe the capacitor was not charging not because of properties of currents in collector and emitter for any NPN, but because i've been thinking in terms of conventional current...
Let:
Q be a sub-circuit of an avalanching transistor and capacitor in parallel. in my case, the avalanching transistor is 2N2222;
the "generic NPN" is not the 2N2222 mentioned.
whenever Q was in the emitter side of the generic NPN, the negative terminal of the Q's capacitor is already in the highest negative charge. the momentary opening of the generic NPN's collector applies a "more electropositive voltage" to the capacitor's positive terminal, but there are no charge carriers migrating to said terminal. hence when the generic NPN stops conducting, the "more electropositive charge" is not held.
if we were to put Q on the collector side, the positive terminal of its capacitor is always what it is supplied to it. when the generic NPN starts conducting, electrons rush to the negative terminal of Q's capacitor and when NPN stops conducting, the electrons stay there. hence, we have negative charge there.
is this correct? i'd appreciate it if somebody would confirm this.
