Question electrolytic capacitors in devices
nogueiraat
Apr 24, 2021
38
i store my devices were manufactured in the early 90s and early 2000 and their aluminum electrolytic capacitors are original. The devices work normally, but I read that aluminum electrolytic capacitors stored for long periods without use present failures and I would like to prevent these failures due to disuse by energizing the devices here at 220v for a safe period of time to prevent failures due to disuse.
My conditions are temperature varies 32-35C in 24h, humidity 57-66% without rain.
in my case what frequency energize devices and minutes for prevent fails disuse
BreanneJJustice
Sep 23, 2021
4
Electrolytic capacitors play a critical role in many devices, especially in filtering and smoothing circuits. When selecting replacements or designing new projects, voltage ratings and capacitance tolerances are key factors to consider. For a wider range of options and detailed specifications, check out Capacitors to find components suited to your application needs.
All good now?
