0 ohm resistor
spleblem
Mar 30, 2005
54
hey guys
is there any point to a zero ohm resistor
thanx spleblem
audioguru2
Apr 6, 2004
12,022
A zero ohm resistor is a jumper wire for a pcb that can be installed by the same machine that installs resistors.
steven2
Jan 19, 2004
1,698
:)a super conductor isent that suposed to be zero ohms , and i supose if ya take a resister out ya have no ohms at all so hence the zero ohms hmm ill leave that to audio guru, him exspert  in the electronics feild
MP1
Dec 7, 2003
3,397
Zero ohm? All wire has some resistance. You can look at a zero ohm resistor as a value with not enough resolution. Add the decimals places and you would have some small value there.
MP
trigger
Aug 7, 2004
234
What I know is, some products keep a resistor footprint for adding EMC components for Lab test while they will use a 0ohm resistor for shipment product...... what for...... reduce cost  :p
windoze killa
Mar 4, 2006
136
We use 0 ohm SMD resistors all the time. They are mainly used as links. We design the boards so there are different configurations available. The resistors are placed to select different options.
gogo2520
Aug 14, 2005
495
Hello
OK you got me where can you buy zero  Ohm resistors, I think a jumper wire has more Ohms then zero.
                                  gogo
N
nanop
  I've seen jumpers inside TVs before soldered right along with resistors. R they those staple looking things?
What are they used for?
What are they?
windoze killa
Mar 4, 2006
136
Trigger said:
It acts like a small inductor in some cases.
I missed this post before. Not quite sure hore you can make this statement. A small chip of metal film with 0 ohms would have such an insignificant inductance it would be useless. About the only way I could see this happening is if it was a wire wound 0 ohm resistor
indulis
Nov 21, 2005
488
Actually, wire wound resistors do have inductance. As far a wire, it's about 20nH/inch.
Yup... zero ohm jumpers can be/are used for configuring different options. They are also used a as "bridge". When you have to keep cost's down, manufacturers use them to avoid having to go to a double sided PCB. A few "jumpers" are a LOT cheaper than drilled plated via's on a multi-layer PCB (as in double sided and up).
