0 ohm resistors
Diarmuid1
Mar 5, 2006
21
On an audio circuit I am copying, there are a lot of resistors with just one line, a black one in the centre.  As in the colour code, black is 0 are all these resistors likely to be 0 ohms and thus can I just replace them with normal wire?
Thanks for your help
Diarmuid
logan_dslasher
Jul 23, 2004
392
huh!?! i never knew that!  :)  and i definitely haven't seen one.. so, they are just simply, JUMPERS! duh?! why would anyone want to manufacture them? what is their importance?
ante1
Jan 24, 2004
4,138
Hi logan,
The machines which put together the pcb:s can recognize a dummy resistor but not a piece of bare wire.
audioguru2
Apr 6, 2004
12,026
Hi Logan,
The "zero ohm" jumpers are the same physical shape as a resistor so therefore are able to be handled and placed on a pcb by automated machines that install resistors on pcbs.
Same idea as Ante.
logan_dslasher
Jul 23, 2004
392
ahh... so that's what they are for... thanks  :) for the explanation, both of you..  8)
hotwaterwizard2
Jan 8, 2004
2,022
Also sometimes a regular jumper will ark and a wire will melt off the insullation under heavy load conditions.
indulis
Nov 21, 2005
488
Typically they are used as jumpers on PCB's when cost has to be cheap, as in single sided or no thru plated holes. To put "ampacity" into perspective, it takes 10 amps to fuse a 30AWG wire.
prateeksikka
Jun 19, 2004
736
hi....
10 jumbers v/s 10 resistors....
where goes the cost of the system.well do u people say that these are used in automated systems which manufacture the PCBs by soldering the components?
thanks for reply in advance
