Hi Staigen,
Didn't you see my FM transmitter? I found some tiny variable caps to tune it, it has a low-distortion preamp with proper selectable pre-emphasis, the preamp and oscillator have a low-dropout regulator, it has an RF amplifier/buffer so that it doesn't change its tuning if something gets near the antenna and its range is more than about 2km. My FM band is full, so to test it I had to use the same frequency as a foreign-language low-power station on the other side of my city. ;D
To Audioguru
Yes, i have seen it before, here on the board, a nice little thing, built on a wero and all! Nice! ;D ;D
BTW, have you notice my message(question)?
Hi Staigen,
You are absolutely correct! My coils are only 100nH. I think Walid recently posted an FM transmitter circuit using 100uH by mistake and I didn't notice its error. :-[
OK OK guys it is 100uH coil and i can't purchase it, can i use a piece of ferrite rod and wound some turns on it? IF this OK what values (rod length and diameter, n turns etc)
I guess the ferrite core is a Philips one with 6 holes for the wire to loop through and has 5 turns of wire in it.
Entering Ferroxcube in Google linked to a site by Ferroxcube. They have a few of these cores and the ones with the highest inductance resonate below 100MHz. Here is a good one:
