100MHz clock Oscillator CFPS-73 test circuit
azher_bashir
Jan 25, 2012
Asalam O ALikum,
I am working on 100MHz clock Oscillator CFPS-73 test circuit according to data sheet. After PCB designing of test circuit When i apply voltage souce, the oscilator was not draging any current. It menaz that its not working?Can any 1 suggest that is there any probelm in circuit or any other reason.....
Here is the link of data sheet inclusive of test circuit.
http://www.iqdfrequencyproducts.com/products/details/cfps-73-12-01.pdf
Resqueline
Jul 31, 2009
2,848
Most likely there is an error (a mistake) in the PCB layout (design).
Rleo6965
Jan 22, 2012
585
Double check etch of pcb if connection was on correct pins of Clock Oscillator and broken connection.
14,486
hi welcome to the forums :)
the current drain is very small ~ 20mA, how were you measuring the current drain?
did you have a frequency counter on the output to actually see if there was a signal being produced ?
vinit2100
Oct 21, 2013
100
1.First check the schematic symbol of your oscillator and cross check the pin number.
2. Pin number 1 (PAD 1) should be either connected to VCC or left unconnected.
