110/120V inline ammeter.
Martaine2005
May 12, 2015
5,318
Hi forum friends,
It’s not always easy or possible to open site tools (110V) to measure current by opening the circuit and putting the meter in series.
I am looking for a plug in device inline with the tool and transformer. 240V versions are readily available everywhere.
The 110V transformers are centre tapped.
Also a clamp meter is impractical as I still have to open the tool or cable to get to the single core.
Anyone got any ideas on an easy DIY inline ammeter?.
Thanks. Martin
Kiwi
Jan 28, 2013
507
If you only need to measure current just make a short extension lead and remove the outer sleeving from a short piece in the center to expose the conductors to use a clamp meter. Perfectly safe as long as you don't damage the insulation on the conductors.
Martaine2005
May 12, 2015
5,318
Yes, I did start doing that. But then I needed a 16A to 32A adapter and vice versa. I was hoping for an all in one inline ammeter similar to the photo I found on the WWW.:)
Martaine2005
May 12, 2015
5,318
Thanks for the ideas.
I opted for a cheap easy solution. I purchased a meter (photo below) and will house it a plastic box with 110 and 240v plugs along with 16A and 32A outlets.
Hopefully it’ll be somewhat accurate:).
It’s supposedly 50VAC - 500VAC, 0A - 120A. It will never see anything above 30A.
