11ak30 chassis
b
Hi there,
vestel 11ak30 tv.
here's the story so far...set had a shorted HOT (would not come out of
standby, if keys pressed set just chirped and red led stayed on). Set
powered up fine without HOT in place. Connecting bulb across c-e showed
b+ OK. No obvious solder problems, just resoldered one or two slightly
suspect joints.
Now for the annoying bit: Replaced BU808DFI HOT and c618 (according to
schematic,7n2). New transistor blows out immediately. Now suspecting
LOPTX shorted internally, before I replace it though, has anyone seen
this problem before on this chassis?
best regards,
Ben
b
b ha escrito:
Hi there,
vestel 11ak30 tv.
suspect joints.
best regards,
Ben
For the record:
replaced HOT BU808DFI, and LOPTX (HR 7950), also 10uF 63v horiz drive
cap and 8n2 cap across HOT. Set now works.
-B.
jonhyr19
b said:
b ha escrito:
For the record:
-B.
jonhyr19
b said:
b ha escrito:
For the record:
-B.
hi I am newby in tv repair, sory for stupid questions, what did you
meen when you say HOT?
and when you say : cap and 8n2 cap across HOT.
Thanks....
jonhyr19
jonhyr19
b said:
b ha escrito:
For the record:
-B.
Thanks....
jonhyr19
b
jonhyr19 ha escrito:
Thanks....
jonhyr19
no need to apologize. if everyone simply asked for information or help
whenever they didn't know or weren't sure about things, the world would
be a better place!
Thr HOT= HORIZONTAL OUTPUT TRANSISTOR aka LINE OUTPUT TRANSISTOR.
CAP= capacitor, in this case i changed two. One electrolytic type in
the horizontal drive circuit (apparently prone to failure on this
chassis) and also another polyester film type, value 8n2 , connecetd
c-e across the aforementioned HOT transistor.
see
http://www.interq.or.jp/japan/se-inoue/e_capa.htm
and
www.repairfaq.org
tv troubleshooting section.
going back to the above parts, I usually test or change these parts
first of all in any set with shorts or other problems in the horizontal
stage, before moving on to the more expensive transformer. They suffer
a lot in use and are generally (relatively) cheap and easy to get hold
of.
hope this helps.
-B.
jonhyr19
be a better place!
see
and
www.repairfaq.org
of.
hope this helps.
-B.
Hi again
I have two tvs with problems one with 11ak30 and 11ak30-1
on 11ak30-1 i replaced HOT BU808DFI, and LOPTX (HR 7950), and all ok
problem resolved
on 11ak30, nothing apend, the aparent problem, the tv stay on standby
and the red light flash, and a sound with the flash, if you toutch in
any boton the light pass to green and again in red, and noting apend.
HOT BU808DFI, and LOPTX (HR 7950) are ok, what seems to be the
problem?
jonhyr19
b
Hi again
problem resolved
problem?
jonhyr19
sounds like there is something shutting down the power supply.
first, check the voltage on the HOT. unsolder the HOT and connect a
60-100 watt bulb across c-e terminals.switch the set out of standby to
ON, see if the bulb lights and is steady.
-Set your voltmeter to DC and put the red probe on the c, black to e.
measure the voltage (should be between 115 and 130v depending on size
of screen). try replacing the 160v capacitors in the b+ line from the
power supply if it is not.These sometimes fail causing this problem.
-try also unsoldering the outputs from the line transformer, and power
supply transformer one by one to see if there is one shorted bringing
down the power supply. (vertical, RGB, etc etc.)
note that these are all very general tests, see www.repaifaq.org for
more details. it's a bit hard to be more specific over the internet,
without seeing the TV set!
regards,
B.
jonhyr19
regards,
B.
When i put the bull in c and e something in HOT die and the light of
standby desapear..
jonhyr19
