James Lerch
- Jan 1, 1970
- 0
So, I built this generator a few years ago. The thing is based on
1930's technology, its just plain simple and works (for the most part)
My old BackUPS 1400 finally got to the point I was tired of fixing it,
so I erroneously replaced it with a SmartUPS 1400. Bad Idea, when I
switched over to generator power in preparation for this years
hurricane season the SmartUPS were too smart for their own good and
wouldn't switch back over to "utility" power.
A few years ago when load testing the generator, I noticed that the
stone age rotor power supply, while incredibly simple being built from
only a rectifier, didn't put out very clean power. On my "ToDO" list
was to build a more involved voltage regulator with an integrated
engine management system (mostly because it sounds like a neat
project, not because the system really needs it)
So anyway, I hoped that the noisy voltage output from the generator
was source of the SmartUPS problems. With a little experimenting I
found that 66vdc @ 5amps applied to the rotor winding made fairly nice
looking 250vac sine wave output at 60hz no load. When a load was put
against it, the voltage dropped down to 240vac and I thought for sure
the SmartUPS would be happy (the o-scope showed rather clean
sinusoidal waveforms). Not so much...
OK, SmartUPS must be un-happy with the frequency changing between
power strokes, maybe having problems "syncing up" or something.. But
fixing this is a problem.
#1 The ST generator head rotates at 1800 RPM to produce 60hz power.
#2 The 1 cyl diesel is direct attached to the generator head.
#3 While the diesel has a MASSIVE (24" diameter 2" thick) solid cast
iron flywheel, I can still see the frequency change during each of the
4 cycles of the diesel engine.
Bottom line, for each revolution of the engine I produce two complete
output AC waveforms from the generator. Every other revolution of the
shaft has a power stroke from the single cylinder diesel. So I get
one complete wave form during the power stroke, another during the
exhaust stroke, another during the intake stroke, and another during
the compression stroke. End result, the damn frequency of the
generator is constantly changing (would you call that a "sub harmonic"
or something?)
ANYWAY, the question to you scholarly folks is "What's the most direct
approach to get the SmartUPS back on-line during an extended power
outage"
Towards that end, here's my current thoughts, but I don't really like
any of them.
#1 Replace 1cyl diesel with 4cyl engine (yuk on many levels, but
probably the most "appropriate" solution. BTW, I now know why most
large generators use 4cyl prime movers.....)
#2 Just Don't use the SmartUPS during a power outage (duh). I mean
really, the cable company runs out of battery power in a few hours
anyway, so what could I be running that needs battery back up? But,
where's the fun in this solution
#3 Get a big battery charger and connect it to internal batteries on
SmartUPS, add extra cooling and hope SmartUPS doesn't cook itself
while running on batteries for extended periods. (YUK)
#4 Put "Something" between outlet and SmartUPS when on generator
power. Such as:
A) AC -> DC -> AC converter (wow redundant)
B) Transformer -> 60hz LC tank circuit -> Transformer
C) magic pixie dust.
So any other thoughts?
Take Care,
James Lerch
http://lerch.no-ip.com/atm (My telescope construction,testing, and coating site)
http://lerch.no-ip.com/ChangFa_Gen (My 15KW generator project)
"Anything that can happen, will happen" -Stephen Pollock from:
"Particle Physics for Non-Physicists: A Tour of the Microcosmos"
" Press on: nothing in the world can take the place of perseverance.
Talent will not; nothing is more common than unsuccessful men with talent.
Genius will not; unrewarded genius is almost a proverb.
Education will not; the world is full of educated derelicts.
Persistence and determination alone are omnipotent. "
or something?)
outage"
any of them.
power. Such as:
Take Care,
James Lerch
