24VDC Relay Driver switching 240VAC 10A Load
Ben Halicki
Sep 3, 2015
10
Hi Guys,
I need someone to help me design a schematic for a basic relay driver (24VDC feed from PLC into optocoupler, which drives a relay). Pretty basic, but my main question is around the relay.
The relay needs to switch 240VAC loads (up to 2400W / 10A). Is it possible / safe to have the relay mounted on PCB and be able to handle this sort of current, or would I be better off using an externally mounted relay?
Thanks in advance,
Ben.
14,487
Hi Ben
there are proper SSR ( Solid State Relays) available for this sort of thing. I would strongly suggest you get one of those
It will simplify your project and be a hell of a lot safer :)
google 240V switching SSR's
Minder
Apr 24, 2015
3,561
Another solution is to use a contactor, these are traditionally a large form of a relay so it would be mounted separate to any PCCT board.
M.
AnalogKid
Jun 10, 2015
3,058
With proper attention to trace width and copper thickness (weight), a pc board design can handle your voltage and current easily. After all, they are common in many power supplies.
Since a relay has true galvanic isolation, why do you have an optocoupler between it and the PLC? Very few optos can move the current needed by the coil of a relay with those contact ratings.
ak
Tha fios agaibh
Aug 11, 2014
2,253
Why not just buy relays with 24vdc coil?
Btw, If your plc output card has common terminals for internal contacts, you can feed it with other than 24vdc.
Example; feed common terminal with 120v so it outputs 120v. Of course you need to observe its rating.
14,487
he's dealing with higher voltage and significant current
SSR's are a very way to handle that
Tha fios agaibh
Aug 11, 2014
2,253
he's dealing with higher voltage and significant current SSR's are a very way to handle that
I agree, but SSR's can get expensive and they tend to fail more often than a mechanical relay.
A relay or contactor (coil) that matches the PLC output voltage is usually the best plan.
I wasn't suggesting attaching the load directly to the PLC output card. I was merely noting that a PLC can often be rewired to suit the output voltage desired for a relay that one might already have on hand.
Ben Halicki
Sep 3, 2015
10
Hi guys,
Thanks very much for the suggestions. Sounds like using a SSR might be the way to go.
Out of interest... the current measures around 9.6A. If I have a 10A relay, to me that is probably too close to the upper limit of the relay, but interested to hear your thoughts. Apologies in advance for digging up an old thread, I thought i'd posted this a while ago but apparently not :)
AnalogKid
Jun 10, 2015
3,058
The standard rule of thumb for electronic components (overrate everything by 100%) applies in part to an SSR. For a 10 A output current, use a 20 A part. You do not have to overrate the voltage spec, because an SSR with a max output rating of 240 Vac is designed to handle that continuously.
ak
Minder
Apr 24, 2015
3,561
Re-reading the OP, why exactly are you using a Opto coupler from the output of a PLC to drive a relay/contactor?
Why not drive the SSR or relay direct from PLC output?
I see it was suggested in #4
M.
