12v 4A power supply
Sadlercomfort
Ash
Feb 9, 2013
424
Hi guys,
My friend is working on a project, but he needs a supply which takes 230v on the input and 12v 4A on the output. What is the simplest way to create this supply circuit? I imagine some of the components might be expensive as well, because of the 4A on the output.
Ash
14,309
For a do it yourself project, the simplest, albeit not most effective way, is a transformer, rectifier, filter capacitor and regulator. A suitable regulator is e.g. here or here.
A switched mode power supply is more efficient, but is more difficult to get working.
A very simple solution would be a used PC power supply which is efficient (switched mode), ready to run and inexpensive to come b(u)y
It will also deliver more than 4A without problem.
duke37
Jan 9, 2011
5,364
It depends on whether the output is AC or DC and what stability is required.
A simple solution for a 'dirty' supply is to use a simple old style battery charger with a big capacitor on the output. You will get DC at more than 12V.
The difficuty in building your own supply is boxing it up to be safe and a 50VA transformer will be quite pricy.
Added to Kris' reply, try to find a PC power supply that doesn't need a load on the 5V rail (I have one that specifies a "Minimum load 0A").
Also note that the 12V is typically rated as +/- 10% although they're usually a bit tighter than that.
