12V LED dimmer/timing circuit advice required, please!
Dungeon Dave
Hi, all. Relative newb here - relative in the sense that I used to dabble
in some electronics as a youngster and did some electronics theory in A-
level physics but that don't make me an expert as such.
Okay, so onto my problem. I bought a set of these the other day:
http://www.wickes.co.uk/Kitchen-Lighting/Accent-Ten-LED-Indoor-Light-
Kit/invt/190803
(actually, that doesn't look like the right package, but it'll do for the
purpose of this query)
- they're a string of white "nail" LEDs that are intended to mount in
thin plinths, powered by a plug-in transformer that delivers 12V to a
matchbox-sized distribution point. Since the DB just consists of 13
powered sockets in parallel connection, I'm guessing each LED has a
resistor in series to provide the correct voltage across the LED itself
(they may be bright, but I ain't heard of any LED that can take the ommpf
that 12V will pack and survive for too long!)
During the day, these lamps are bright enough, but I want to subdue them
for evening and night usage (I'm planning on leaving them on as
nightlights on the stairs, etc), so thought of just using a 12V dimmer of
some kind. Bill Bowden's site came up in a few google searches, and was
thinking of employing something like:
http://ourworld.compuserve.com/homepages/Bill_Bowden/page6.htm#dimmer.gif
(the site directed me to this forum)
However, it had me thinking: firstly, I have a transformer to drop
240AC->12DC, then another circuit on to lower the 12V... would I benefit
from combining the two into one? Build something that delivers a
rectified 2-12V output (looks like 5W max, BTW)? If so, are there
diagrams/kits (Vellmen, RS Electronics etc) readily available?
Secondly, I'd like to combine this with a timer circuit in some way, so
that it'd fire up at 100% brightness at one set time, dim to 20% (or
whatever preset I use) at a second time, then turn off completely at a
third time. I was toying with the idea of linking in a serial feed from a
USB controller then firing control information from my server (Linux,
running 24x7) so I could easily schedule something that determines what
brightness at what times of day I require, letting that ramp up/down the
lighting as I see fit. I've seen various projects online that cover this
info, but before dipping my toe in there, are there any more readily-
available circuits that can do this kind of timing-based control? Could I
hack away at a central heating controller? I'd prefer to have the self-
contained wall-mounted jobby if possible.
Okay... I know expecting someone to design something that exactly fits my
needs is asking a lot, given I've just strolled in here. However, I'm
guessing that if I'm going ot be reinventing the wheel through my
ignorance, I'm hoping someone can at least put me on the right road.
Thanks in advance, people!
Kit/invt/190803
http://ourworld.compuserve.com/homepages/Bill_Bowden/page6.htm#dimmer...
You already have the 12V supply, so I would keep it as part of the
project. For one thing, this prevents you from having to deal with the
mains. There are probably several LEDs in series, plus a resistor. I
don't think they would use 12V per LED since the drop across the
resistor would be high.
What you want to do is pulse width modulate the power to the LED. That
is, let duty cycle control the brightness.
Most cheesy PWM circuits consist of a sawtooth generator which you can
make out of a 555, and a comparator.
Jasen Betts
555-based PWM lamp dimmer, a good choice.
Bill's circuit doesn't reduce the voltage (much) what it mainly does
is reduce the on-time of the LEDs (by blinking them at a rate that's
too fast to see) this is a very power-efficient way of dimming lights.
third time.
an irrigation controller perhaps ? this is way more complicated than
Bill's PWM dimmer. it may be easier to hack a few electronic timer-plugs
and use their timers to control on-off and brightness.
OTOH it would be easy to wire a light-sensor a variation of bill's dimmer
circuit so that when it sees "dark" it dims the lights and just use
the timer plug to turn them off when you want off.
One thing to consider when chosing between a switched (pulse width
controlled) dimmer, and some linear system, is that in pulse width
modulated
LED supplies you get a sort of stroboscopic effect when your eye scans
accross
the LEDs (you see more then one, some distance apart).
If you do not like this, then use DC.
USB controller
As you are not very experienced, maybe it would be simpler to use the
serial port.
For example to write to an antique UART, and use the 8 data lines to
for
example drive a resistor R2R network to make an analog voltage to
drive the brightness,
for example drive a 2N3055 emittor follower.
That will save you from programming a PIC.
Here is a simple serial communications program for Linux:
http://panteltje.com/panteltje/pic/io_pic/ptlrc-0.3.tgz
Dungeon Dave
project.
okay. It's one less headache, I guess.
Nor me, but the transformer claims it's chucking out that and these are
somewhat superbright LEDs. I'll get a multitester on the DB and measure
the voltage at the parallel end, see if it really is that much.
okay.. I recall some diagram that had a strobe-like effect to simulate
dimness, although it looked more like a square wave (I could probably pop
some caps across the output points to smooth out the wave).
Ta for the help!
Dungeon Dave
modulated
accross
Given they're not going to be near anything else strobing (overhead
lights @50Hz, monitors/TVs etc) I wasn't too bothered about the strobing
effect, but I know what you mean. Would upping the PWC frequency to
something much higher (maybe in 200Hz range) disguise the strobe effect?
[OS-based controller]
serial port.
for
snagged, untarred and read the README... mmm.. nice! Thanks for that, I
may toy with a few proof-of-concept experiments and that util.
Dungeon Dave
[Bill's diagram]
Can't go wrong with a 555... where would we be?
(don't say "taking a pair of scissors to a 556"...)
lights.
I read that reducing the power output (strobing) is the more efficient
method than splitting it and dissapating the unwanted power elsewhere,
but as we're talking a total of 1W for my lights I didn't know if it was
worth it. I'll have to do some costings.. perhaps I should have done that
first.
(/me ponders a blog...)
[timer]
timer-plugs and use their timers to control on-off and brightness.
mm... never thought of that. Will investigate, ta.
dimmer circuit so that when it sees "dark" it dims the lights and just
use the timer plug to turn them off when you want off.
Essentially I wanted to have the lights at 100% during evening/dusk so
some LDR-based circuit could trigger the "on" cycle, but then wanted them
to dim to "comfort light" after a pre-determined point (20% from midnight
onwards?), so what was an illuminating effect doesn't become too dazzling
to sleepyheads. Bit of a strange requirement, I know.
okay, that's given me some pause for thought - ta for that info!
PeterD
dimness
I can just see one preparing a ham sandwich with a strobe light. The
ehsjr
Yes. Build the Bowden circuit - it runs at 200 Hz so there
is no need to up the frequency. You were also concerned about
the square wave output - that is not a problem, at all. Get
the dimming portion of what you want working first, sort out
the timing part later.
Be sure to check that the voltage coming from the supply
included with the lights is 12 volts DC.
Ed
<snip>
Rich Grise
Yes. Build the Bowden circuit - it runs at 200 Hz so there is no need to
up the frequency. You were also concerned about the square wave output -
that is not a problem, at all. Get the dimming portion of what you want
working first, sort out the timing part later.
Be sure to check that the voltage coming from the supply included with the
This is my recommendation, but I wouldn't use a 2N3053 and 2N2955 - I'd
use something more like a PN2222 and a TIP32, because they're much more
recent designs, with lots of beta and stuff. If you want to switch the low
side, lose the 3053 and just drive a TIP31. They're less than a buck at
digi-key.
And yes, 200 Hz is high enough to make the flicker go away. :)
Have Fun!
Rich
neon
Oct 21, 2006
1,325
LEDS are not resistive lamps whereby linear in resistance. they are exponential devices therefore yes you can controll them some of the way but never like lamps. use to control brightness is just plain unsound idea.
Ta for the help!
No, a rectangular pulse is what you want. Your eye will average the
intensity. The 200Hz suggested frequency is plenty fast.
Dungeon Dave
I'd use something more like a PN2222 and a TIP32, because they're much
more recent designs, with lots of beta and stuff.
okay.. so just replace 3053->2222 and 2955->TIP32?
Roger that.
If you want to
switch the low side, lose the 3053 and just drive a TIP31. They're
less than a buck at digi-key.
I don't know why, but I'd prefer to have the switch at the high side -
something about having floating grounds worry me.
And yes, my idiotic eyesight never actually READ the site carefully and
noticed that! Major DOH! Excuse my noobness/impatience; it's strangely
nice to be on the other side of the clueCurtain once in a while!
Have Fun!
Rich
Ta!
Preacher Kane
Nope - they're paralleled up.. and just checked the voltage. 13.55V at the
supply end!
