Hi
Someone has asked me to build a battery charger. The battry is a 24V / 150Ah from those kinds which is used in big vehicles. I think they Are called Lead acide battery!!! Am i Right?
the battery is to be charged with a max Current of 15A! I decided to charge it with a circuit like the one I have attached, because of High current for my circuit, I decided to use TWO ATX (PC power supply) 12V rail. {They are 16A Nominal}, but the problem is how do I limit the current at 15A.
I have an Idea, Tell me if it works:
There is a pin in ATX Ps which is for Stand by, And PC pull it down to Start the ATX. I want to use a .05 Ohm resistor at the output and when Over-Current Happen, Pull this Pin Up? Can I have a current Control In this Way?
Of course, I have to increase 12V rail of Two ATXs a little bit higher to creat 27V (13.5 + 13.5 Two ATXs in series) to Charge Batteries.
ThanX
Shahriar
Battery_charger.pdf
ThanX
Shahriar
Battery_charger.pdf
