15kw motor as generator?
Michael C
I friend of mine came across a couple of nice looking 15kw 3 phase electric
motors. He's also got a small turbo 3 cylinder diesel engine. If we join the
2 up will electricity come out the electric motor? If not is there some way
to get it so it will?
Thanks in advance,
Michael
Mauried
Thanks in advance,
Michael
Most unlikley.
Modern 3 phase motors are induction motors which means they have a
solid rotor , which turns in the rotational field caused by the 3
phase current on the stator windings.
They wont work in reverse as there is no magnetic field present in the
rotor.
No easy way to convert either, unless you can find a permenant magnet
rotor which will fit in place of the solid rotor.
Phil Allison
"Mauried"
"Michael C"
Most unlikley.
rotor.
** Like " pissing through a keyhole " - it can be done - but why bother
http://www.otherpower.com/otherpower_experiments_motor_convert.html
....... Phil
Michael C
Bruce Varley said:
Assuming them to be squirrel cage induction motors, Google on Induction
Generator. If you plan to run them autonomously, using capacitors, that's
a fairly chancy setup, stabilising the output voltage is difficult. If
you're supplementing an existing, reasonably stiff grid, then it's a lot
easier. The machine just excites off the grid and feeds power back in when
it's run above the synchronous speed.
I assume that you're thinking of 3-phase generation?? If single phase,
then there are other issues.
I think I'm over the idea :) It sounds like a bit too much trouble. Better
to sell the motors and buy a generator.
Michael
