+/-15V power supply using LM317 and LM337 regulator ICs
cyw1984
Sep 7, 2005
63
How to designa +/-15V power supply using LM317 and LM337 regulator ICs.
Thx
The voltage is used to DAC (AD669)
I have try to design the circuit....
Is it Right??
audioguru2
Apr 6, 2004
12,022
Hi Cyw,
Your circuit is correct for a dual-polarity supply having adjustable output voltages from 1.25V to about 27V.
You don't need an input voltage as high as 30V when anything more than 18V will be fine.
You don't need pots to adjust the output voltages when 2.7k (5%) resistors are fine to produce 15.3V outputs. ;D
cyw1984
Sep 7, 2005
63
audioguru said:
Hi Cyw,
Thanks a lot~~
I need pots to adjust the output voltage
because it is use for  V reference .....
My AD669 DAC Vref is given by this +-10V
Alun
Can't you just use a 2.4K resistor with a 500R trimmer in series?
audioguru2
Apr 6, 2004
12,022
cyw1984 said:
+- 15V is provide thw power of AD669 (VCC,CEE)
Then since the supply range of the IC is very wide, you don't need the pots, just 2.7k resistors instead for +-15.3V.
