18650 batteries not charging
camilozk
Apr 20, 2014
122
Hi!
I bought some 18650 batteries in ebay (http://www.ebay.com/itm/4x-6000mAh-...569397?hash=item3d00366335:g:ndwAAOSwgQ9VxTXR). They are probably not good quality, but it is so difficult to know when you are buying good batteries and when you are buying crap...
The thing is that I havent used them so much, just a couple of times, and now I was using one until total exhaustion. When trying to charge it again, it doesnt charge it. The charger displays immediately its green light, which is supposed to mean that the battery is now full.
Is there something to do to force the charge?
How does the charger operates? When does it charge and when does it stop charging?
If the battery is faulty, what does this exactly mean?
thanks in advance for your patience and ideas
cjdelphi
Oct 26, 2011
1,166
I've read stories of 18650 cells simply being removed from dead laptops repackaged and sold on ebay!
Lithiums are easily destroyed by completely discharging it... to "revive" it enough to charge you need to supply it a few hundred ma of current at 4.2v until the voltage is high enough for the smart charger to continue charging it...
Resistor/current limiting
cjdelphi
Oct 26, 2011
1,166
Either no protection or the cells are really bad, a true 2600mah battery costs around $20
