1996 Fender deville deluxe 212
jsnead
Mar 6, 2018
I have a fender deville that is producing extreme distortion on channel 2. Channel 1 is clean and sounds great.I have recently replaced resistor #57 that cleared up an output issue. amp played fine after repair but when owner got amp back this issue developed.
Any suggestions?
HellasTechn
Apr 14, 2013
1,579
Hello and welcome to our forum !
A more detailed explanation will be essential before we can issue assistance since we dont know exactly what you have or what you have done to it. For example: brand, model, schematic if possible (or link to it), photos of the board if possible. That way our suggestions will be better aimed.
73's de Edd
Aug 21, 2015
3,730
How do you get this channel 2 reference ?
The unit is a mono amp and the only 1-2 aspect is the two inputs 1 and 2 and they then tie into the same common input junction .
Geoffrey Barber
Feb 26, 2018
Hi, The Fender Deville (like all modern 2-channel guitar amps) has been designed so channel 1 is the clean channel and channel 2 is the overdrive or distorted channel. Again on most modern guitar amps you will find 2 input jacks one jack is designed for standard or non active guitars and the other for active guitars, nothing to do with channel 1 or 2. If you plug a standard guitar into say input jack 1, it will sound louder than input jack 2, this is because input 2 will attenuate the input signal by half to accommodate an active guitar which give double the output.
