My Fender Deville has some symptoms. 1. The clean channel has barely any volume, and does not change volume when the volume knob is turned. 2. The distortion channel has a pulsating sound with or without an instrument plugged into the input of the amp. I've checked the power supply with a voltmeter and oscilliscope and that looked normal. I do measure a "partially rectified" or "large ripple" voltage on the 100k anode resistors (R11 and R16) for preamp tubes V2A and V2B (12ax7) on the oscilloscope. The volt meter measures 3vac on R16 and 4vac on V2B. A 100k resistor is connected between a relay switch and the grid of the V2B tube. The voltage at the grid resistor is 57vac on one side and 27 vac on the other side of the resistor with (with reference to ground). I am wondering if the grid voltage or anode voltage are causing this pulsation on the distortion channel? The clean channel I haven't really checked yet. Could the clean channel symptom and the disortion channel symptom be related to the same problem with the amp, what could be the cause of these problems?
