Can diodes 5408 and 5404 be used in common? Thanks in advance.
ROSELJR1 Jul 9, 2021 2 Joined Jul 9, 2021 Messages 2 Aug 26, 2021 #2 [SIZE=10.5pt]Can diodes 5408 and 5404 be used in common?[/SIZE] Thanks in advance.
HarryA1 Mar 4, 2009 481 Joined Mar 4, 2009 Messages 481 Aug 26, 2021 #3 You can use the 1N5408 in place of the 1N5404 and you can use the 1N5404 in place of the 1N5408 if the voltage is less than a peak reverse voltage of 400 volts.
