2.5mm heaset plug to 3.5mm audio computer jacks?
D. G.
I bought one of these tiny wireless headsets,
http://www.headonwireless.com/headonwireless.htm
Quite amazing, it does work as advertized, at least with my cellular phone.
However I would like to adapt its 2.5mm stereo jack (3 contacts for ground,
speaker output and microphone input ) to the 3.5mm stereo jacks on my laptop
computer (for Internet chatting and Skyping). So I need some kind of
adapter.
Is there such an adapter on the market?
I did some Googling but no luck so far. I would prefer a prebuilt adapter
otherwise I'll have to do it myself but in that case it wouldn't be as
compact.
Dan
Rich Grise
adapter.
compact.
You don't say what country you're in, but Radio Shack should have
a bin full of them. You plug the 2.5mm plug into a hole in the back
end of the adapter, and the rest of it is a 3.5mm plug. You might
want to check for "polarity", i.e., whether the mic and speaker
contacts are different for your dongle and your laptop, in which case
you'll have to do some hacking anyway. :)
Good Luck!
Rich
K
Keith Williams
adapter.
It's not clear to me what you want. Your cell phone has a 2.5mm
jack. AIUI your headset has a 2.5mm plug. You want to plug the
headset *plug* into your laptop's 3.5mm jack?
Sure. If there are standards, there's an adapter go go between
them. That's the great thing about standards, there are so many to
choose from (and so many people willing to take your money).
In any case, here is a 3.5mm plug to 2.5mm jack (I think that's
what you want) for $5:
http://www.search.com/search?tag=se.fd.box.main.search&q=2.5mm+++3.5mm+++adapter
Here is its reverse (also $5):
http://www.proporta.com/F02/PPF02P05.php?t_id=745&t_mode=des
compact.
Did you try; "2.5mm + 3.5mm + adapter"? ;-)
adapter.
compact.
Dan
I did the reverse - took my old headset from internet chat days and
modified it to fit my 2.5mm cellphone.
Bought a cheapo cellphone headset from the 99cent store, hacked off the
cheap headset guts and soldered on the internet chat headset wires.
There's a ground, a mic line and a speaker line... trial and error,
then soldered...
D. G.
Sure I know about one 2.5mm to one 3.5mm adapters...
however I have to go from "one" 2.5mm plug to "two" 3.5mm jacks. Somekind of
Y adapter.
Anyway I finally built it myself this weekend and it's working now. I also
found out the company got a model for VoIP for computer use but it is not
available (yet) in New York.
Thanks for your suggestions!
Dan
K
Keith
Y adapter.
Ok, go from the 2.5mm plug to a 3.5mm jack, then get a 3.5mm 'Y' cable.
