2 Different power supplies: Connecting V- together
Noise
Jan 27, 2016
3
Hi everybody,
I have a rack where there are two different power supplies. I would like to avoid gnd loops, or dangerous short circuits. Is it safe to tie all '-' terminals together? If so, should I connect the earth terminals, which are already connected to the rack chassis, to the common '-'?
Tha fios agaibh
Aug 11, 2014
2,253
It sounds fine to me. You can either tie all your "-" (negatives) to earth ground, or just tie the two together and have a floating neg rail.
As long as your grounds are tied together at the source only you won't have ground loops.
