20p with keyfob for garage door
N
Neo
I am using Vista-20p with a wireless reciver. The home owner wants
to open and close the garage door with a keyfob. Since I am
relatively new on this panel dont know how to do this. anyone can
help me out
Thanks in advance
Neo
A.J.
You can either use the output on the keypad or the onboard relay output.
JoeRaisin
help me out
Thanks in advance
Neo
Onboard relay to close the circuit but you will need a wire from the
opener to your panel. Programming can be a bit tricky but if you read
carefully and take your time it usually goes smooth.
If you are using the RF keypad the should be a relay on it as well but
whenever I try using the onboard zones or relay on the keypads I always
get mighty confused and end up calling tech assist - then i get it working.
Tommy
If he dosen't already have a keyfob. try a street smart code encryptor. much
less programming.
N
Neo
Relay on the keypad do you mean on a 6150 RF , How would I do that
please do help me out the service date is nearing.
Neo
